Home Forum Ask A Member Martin “60” spark plug
  • #258926
      There is a short Champion J8 available but its hard to locate.
      I have given my 75 TS to my son in law to use for fly fishing.
      He fly’s to one end of the lake and fishes for 5 minuets and
      the fly’s to another end. I use these in my motors that need a
      short plug. The LM is for lawn mower so I can find them at
      home centers as well as hardware stores if I need one
      although I have never had a failure. These have been in the
      Martin for 3 years. I put them back in.
      #258927
      JOSEPH BRINCAT
        Tubs, Yes, that Champion plug is available , the problem is that it does not have a screw thread terminal that you need for applications which yse ring terminal spark plug wires. Like on the Zephyrs, I don’t recall the wire termination on Martins.
        #258928
          The 456 number in the chart above cross references to
          J19LM or RJ17LM Champion plugs.
          If the later is a “resistor” plug, I guess I’d opt for the other.
          jimk
            I found 2 AC M44c and it looks like they should do the trick. Also has the screw tops so will work with the martin wires.
            #258971
            JOHN HOLBIK
              All the Champion CJ8 plugs I have the top terminal cap unscrews.
