Home Forum Ask A Member Merc 300 assistance please
  • #8706
    2fast4me
      New to me, 1960 30 HP, electric
      1) what is the battery voltage?
      2) any recommendations on changing the water pump.
      3) I’m not able to shift the LU. I think it’s in forward now.
      Thanks Jim
      2Fast4Me
      #67700
      chinewalker
        1) Uses a 12V battery for starting.
        2) I’d invest in the OEM service manual (part number C-90-25500). Will cover the water pump, and much more. Will pay for itself in saved frustration.
        3) Depending on what it’s doing, it may have been installed incorrectly after a previous water pump service – not uncommon for them to jump into forward with the lower unit off, then get installed without properly aligning the shift rods (upper and lower). A bit tricky, but not difficult. Again, manual is helpful here, too.
        #67702
        20mercman
          This is the book that Chinewalker was talking about. I use mine all the time.
          https://www.ebay.com/itm/Mercury-Servic … Swx3NZZTss
          There are a lot of fans of the Merc 300. A very nice motor.
          Steve
          #67705
          2fast4me
            Thanks guys, i spent some time searching on the JOM site and got that this motor is held in high regard. also don’t touch the magneto without the book. I needed the battery voltage so i don’t blow up the alternator. Hope to start it soon if possible but it’s getting cold out there i want to see what I’ve got before hard water sets in. Thanks Jim
            2Fast4Me
            #67723
              Shift problem may be frozen reverse locks. disconnect 1 of the yellow wires in the rectifier and you wont harm the charging system. 1 914 310 7086. Dave.
              #67752
              fastjohn
                2Fast4Me You have a PM.
