Home Forum Ask A Member Merc 4hp long shaft ….need to know
  • #248644
      not an issue for running.
      #248690
        last question…. what is the part # for the small (slim) twist lock connector (hose end – engine side. ) the newer ones on amazon are to big
        #248694
          I may have one.
          #248713
            send PM re: $
            #248729
              Just checked and must have sold the last one SORRY !
              #248772
              rudderless
                I’ve got a 4.5 hp, 1979. Spark happens at points closing. Mine grounds the ignition module’s output for kill instead of the module’s input from coil. Has a low and high speed exciter coil that feeds the module.
                Yours might or might not have the same ign system though…that serial number might be mag..
                http://leeroysramblings.com/mercury_4.5.htm
                • This reply was modified 4 years, 4 months ago by rudderless.
                #248777
                  Yes I think it is a mag because the spark plug coil is not the external bolt one square with rounded top. the plug wire comes from under the FW like an OMC mag
                  I have a another identical short shaft and it is magneto style with one point like… a 3.9 I also have also.
                  I have a feeling it will be a good runner ….waiting for winter doldrums to open it up.
