Home Forum Ask A Member Merc mark 6
  • #10027
    cdub718
      Need lower unit for mark 6 -any ideas where I might find one
      #76655
      seakaye12
        Hi,
        It always helps to include your location when you place an ad for parts. Shipping can be expensive. In addition you might have better luck using the free classified section.
        viewforum.php?f=69
        Chuck
        #76691
          You and 90% of the people who have one…
          One time I grafted an Elgin lower unit onto one. It was before there were cell phones with cameras; so I have no pictures. I am not a machinist or a good welder by any stretch; although at the time, I had use of a small lathe, where I was able to gas-weld two small shafts together, straight. It worked well and the neutral function still worked. The bonus was that the Elgin unit was a lot more robust than the Merc one, if maybe not quite so streamlined. (Sorry, Carl, but facts are facts.) I sold it to another club member, a long time ago, in a purge.
          #76696
          wbeaton
            I had to tear down three MK6 lower units to collect enough good parts to make one. The lower units are pretty lousy. The plus side is that you can often find a MK6 in good cosmetic condition.
            Wayne
            Upper Canada Chapter
            uccaomci.com
            #76758
            seakaye12
              cdub Check your Private Messages. Click on the Private Message at the upper right hand area of your screen.
              Chuck
              #76761
                It’s a bit late but last year I gave away a good Silent Six gear case. The rest of the motor wasn’t so good and it had to be taken apart with a 12 lb sledge hammer. It didn’t like the salt water.
