Home › Forum › Ask A Member › Merc MK magneto reassembly help
This was probably the only disassembly operation that I didn’t take a picture of (I hope).
when reassembling the magneto would the following order be correct?
sector gear, brass shim, magneto hold down spring
Dave B. We need your help!
I’ll be curious to find out too, facing this on a Mark 25 winter project, she’s in a lot of pieces.
Check out the diagram of Mark 25 on Marine engine.com. I think the brass shim in last
Check out the diagram of Mark 25 magneto on Marine Engine.com. Think the brass shim is last.
Go to Marine Engine and look at Mark 25 magneto. I think the brass shim goes on top of the other two.
Thank you
OK
