Home Forum Ask A Member Mercury KE4 Timing
Viewing 11 post (of 11 total)
  • #174795
    green-thumbs
      Checked 5 Bendix twin cylinder flywheels for Kiekhaefer Mercurys
      3 had two openings 2 had one opening
      All had an opening about 90 degrees ahead of the keyway
      as flywheel in direction flywheel normally turns.
      I believe that indicates which opening to use when setting point gap
      If there is only one opening that is the one to use
      If there are two openings use the one that is at same position relative to keyway
      Or at least that is how it seems to me
      Louis
