Home › Forum › Ask A Member › Mercury kg7 fuel pump
- This topic has 8 replies, 4 voices, and was last updated 2 years, 5 months ago by
JACQUES.
October 11, 2023 at 9:52 am #281534
I’ve been trying to figure out what parts I need to get to run a fuel pump on a kg7 or any green top Merc. I’ve been looking for information on how to hook one up. I’ve read to use a manual k 25 transfer port cover because it has a hole u can thread.What size pump should I use an can I run the aj32 or put a mark 20/25 carb on it.I’m fairly new to this so sorry for my lack of knowledge on the parts are called. Thanks for any help I can get.
Jason chisholm
October 15, 2023 at 10:43 am #281670why would you want to put a fuel pump on it ?
October 15, 2023 at 8:28 pm #281704A KG7 doesn’t have a fuel pump, it is gravity flowIf you want to go to a remote fuel tank you need to change to a pump type caeb too.
October 16, 2023 at 9:59 am #281730I’ve seen videos of people running of an external tank seem cool to me. I thought it was possible to drill the intake port for vacuumed for a pump.
Jason chisholm
October 16, 2023 at 10:42 am #281732you could just drill a 1/4 hole in one transfer port cover put a small square omc pump on a plate (also drill 1/4 inch in line with the pump ‘s rear pulse port .
Before you do all this choose the best port so the pump will not interfeer with the cowl.
the carb should be ok as is.
see OMC mod in picture adjust the plate to match the transfert port cover ….. mount the pump, plate and transfer port with longer bolts .
you may need to resurface the transfert port cover over flat sand paper surface doing figure 8s to make it 100% flat under the new aluminum plate .
attach the pump from the under side of the new plate.
you can off-set the pump so bolt heads will fit in the transfer port cavity just make certain the pulses will reach the pump’s rear port…. apply sealant on the transfert port rim to prevent leaks under the plate
hook up the pump to a new side fuel connector or directly to the fuel tank. hook up the fuel outlet to the carb
all that said and done.. purists will disagree modifying your antique ob
jmho..
October 16, 2023 at 12:24 pm #281737Thanks for everyone posting I’m not sure I could do that set up. I’ve seen something about buy mercury mark 25 port covers with the hole and threading a brass air nipple running to a pump then to the carb but thanks for all the help
Jason chisholm
October 17, 2023 at 12:59 am #281766nippled port work to see mod on a FD … the advantage of the plate version is you only need 2 hoses
October 17, 2023 at 9:58 am #281773If I use the nipple version should I change both port covers or does it matter.I bought some mercury mark 25 intake port covers for easy drilling. What size pump should I use.
Jason chisholm
October 17, 2023 at 11:14 am #281774one nipple one port mofication. the small mikuni pumps should be fine .
suggest you install a small in-line fuel filter on the fuel supply to the pump
