Home Forum Ask A Member MERCURY MARK 55 DRIVE SHAFT SEAL SURFACES
  • #180324
    jrm80
      I’M WORKING ON A MARK 55 AND DEALING WITH THE RUSTED AND PITTED DRIVESHAFT THAT APPEARS COMMON ON THESE OLD ENGINES. SPECIFICALLY, THE AREAS WHERE THE SEALS ARE LOCATED ON THE TOP AND BOTTOM OF THE WATER PUMP. I WAS ABLE TO REPAIR THE LOWER SEAL AREA WITH A SPEEDIE SLEEVE, BUT THAT OPTION IS NOT AVAILABLE FOR THE UPPER SEAL AS THE IMPELLER WOULD NOT GO BY THE SLEEVE IF I WERE TO USE ONE.I HAVE A SIGNIFICANT GROOVE WHERE THE UPPER SEAL RIDES, AND THERE IS NO WAY I WILL GET ANY DECENT SEAL ON THIS PORTION OF THE SHAFT. AS IT IS, IT’S GOING TO LEAK AND THAT’S ALL THERE IS TO IT. MY QUESTION IS, HOW ARE THESE UPPER SEAL AREAS BEING REPAIRED SATISFACTORILY? I THINK I’M HEADED FOR THE MACHINE SHOP REGARDLESS, BUT I WOULD APPRECIATE ANY COMMENTS ON THE BEST APPROACH TO THE FINAL REPAIR. FROM WHAT I HAVE SEEN, PROBABLY THE BEST APPROACH IS SPRAY WELDING AND MACHINING BACK DOWN. ANY THOUGHTS?
      JRM80
      #180326
        Don’t worry about the upper seal. just put the slinger on. 1 914 310 7086
        #180352
        jrm80
          THANKS FOR THE REPLY. WHILE I WAS WRITING MY QUESTION, IT OCCURRED TO ME THAT I WASN’T REALLY SURE I CARED WHETHER THE UPPER SEAL LEAKED AS LONG AS THE ENGINE RAN COOL. I MAY MAKE A WINTER PROJECT OUT OF THIS, BUT IN THE INTERIM, I THINK I’LL JUST RUN IT AS IS.
          #180358
            that is all you need to do.
