Home Forum Ask A Member mercury super 10 model kg-7 bendix coils
  • #229267
    slot gacor
      i was wondering, if anyone knew where to get some coils for the mercury kierraefer hurricane model kg-7 with the bendix scintilla magneto….. thanks in advance!
      Prediski Togel OnlinePrediski Togel Online Prediski Togel Online
      #229277
      RICHARD A. WHITE
        Here is the answer you seek..
        https://www.aomci.org/forums/topic/bendix-single-output-coils/
        classicomctools@gmail.com
        #236201
        slot gacor
          Hey rich I just put that tool in the mail for ya.. But I can’t seem to get to that place were you said here is your answer I seek lol
          #236204
          RICHARD A. WHITE
            Here is the Ebay link for the single output coils…..
            https://www.ebay.com/itm/NEW-Andover-Coils-P-N-9786E128-Military-Standard-Engine-Magneto-Coil-S-1-7/283716294835?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
            Note the output terminal is rotated different from the original but make it point up in your motor and use a bicycle inner tube to keep it from arcing..
            Richard
            #236208
            mike n
              Are these the correct coils for a 1952 mark 20
              mn
              #236209
              mike n
                Sorry I think it’s a 53 and I think the merc # is 399-125. Thanks
                mn
                #236213
                RICHARD A. WHITE
                  Yes, the Military single output will work as a replacement for the 399-125
                  #236229
                  mike n
                    Great thank you. That’s the next motor in the garage
                    mn
                    #236230
                      If you find dual output andovers they work too. Just ground one hi volt output, Now you have a single output andover WITH over twice the windings that equal a much hotter spark. This type of coil goes back to Johnson opposed twin coils. It had contact mechanical points that would ground the left then right cylinder to stop the firing of both cylinders while one was at the bottom of the stroke. Use Super Corona Dope for insulating. Looks like clear fingernail polish & is a super insulater in a bottle. Look under M.G. Chemicals to buy. The corona dope was made back in the day of cathode ray picture tubes, the black & white type. The scanning beam, that lights up the screen is very hi voltage & the hi volt transformer, (Flyback) would arc to ground & corona dope insulated the transformer output terminal & stopped the arcing & the screen stayed bright. CRT’s are very old school picture tubes. Cathode = negative, ray means consentrated light, almost a laser & we all know what tube means, a vacuum glass vessal. Try it, you will like it! Others on Johns old merc have already used it so it has passed the test already ;>) !!
                      Jeff
                      P.S. If you find the dual output coils they are less money because it’s rare that people know how to use it. See above!!
                      Just looked it up on ebay. Some yahoo is trying to get 120 per coil, Don’t fall into that trap!!! They go for $24.00
                      • This reply was modified 4 years, 11 months ago by jeff-register.
                      #236321
                      Ed@deathwish-outboards
                        This outfit has them 14.21ea. but you have to buy 40.00 worth to get free shipping. Otherwise they are not worth it.
