Home › Forum › Ask A Member › Merury Mark 55, 1958 lower unit, small studs, to big studs
Can I drill out the holes in my 1958 Mercury Mark 55, that has the smaller studs in it and mount a Mercury Mark 58 lower unit, that has the larger studs on the Mark 55 upper ???? Thank Rick in Foxburg
Not sure with your 4 cylinder but Merc made stepped studs for early in-line 6’s to swap gearcases, might check it out, Call Joe Poole, he knows,
Hi Rick and Jeff, Yes, they had the stepped studs for the 4-cylinders applications also, and we do have them.
Best, Joe
I knew we could count on you~!!
OK
