Scrounging thru my stash I found an old Michigan two-blade brass prop. LH, approx 7 1/2 dia. would fit a 1/2 in propshaft. The number scratched on it is OB435, which doesn’t match any of the known-to-me Michigan ID codes. The 30’s catalogs available in the IS were not much help. I suspect a Muncie application, but does anybody have a guess what those numbers might apply to ?
This topic was modified 4 years, 12 months ago by retiredoz.
My bible only goes back to ’38, and Hunn’s book is even later. However, since the 4-hp for ’38 is cleverly a 438, similarly the ’39, I’m going to assume this is for a ’35 4-5-6-hp twin. It does have an ‘R’ punched on on the hub, which makes little sense unless this was some kind of racing prop ? I have little info on what Muncie was up to in the ’30s…
Well, isn’t this interesting as all the old Michigan prop lists I see show part numbers starting with an M for Muncie, Neptune Motorgo, and Waterwitch OB series of motors.
OB could stand for Otterbine but I believe they only made small Briggs powered jet drives.
