Home Forum Ask A Member Model R Evinrude carb replacement
  • #240190
    melugin
      I have a decent model R Evinrude, ’27 4 hp. The carb is shot due to pot metal fatigue. I found a Mercury? carb that will physically fit, AJ 38 AX, probably off a chain saw-not outboard. Anyone else tried something similar?
      #240197
      Tom
        At Bill A’s advice, I’ve used a Johnson J carb on a Model N. It should work on the R if your carb adapter flange is intact. The Tillotson from a Neptune opposed twin would be closer to original. But the AJ carb will probably run better.
        Which R do you have? The early one with the Model N Sportwin style lower unit? Or the later one more like a T Speeditwin?
        Tom
        #240796
        JOHN HOLBIK
          Tom how was the J carb did it work as well as the original .I need to replace one on a 26 N as it was broken off by the shipper after an ebay purchase.
          #241185
          melugin
            Found a NOS carb body. Now to try and remove some pieces.
            #241186
            Tom
              I only ran it briefly to confirm the motor ran. I didn’t have a lot of time on it.
              T
