Home Forum Ask A Member motor identification
  • #249860
    Julie Teske
      Hello, Looking for some help in identifying this new find. I have been to the Jack Craib website and it has some similarities of a Caille, but not a perfect match.
      The only numbers on the motor are SR 1714. There is no top to indicate a model or manufacturer.
      any help on where to look for my mystery machine would be greatly appreciated
      motor-5
      motor-4
      motor-2
      #249871
      Tom
        The auxiliary air valves would indicate a Model 30 Racer.
        T
        #249893
        Julie Teske
          thank you
          #249930
            T
            Where are the auxiliary air valves, on the carb?
            Purpose?
            Thanks.
            lyks2tinkr
              They are mounted on the cylinder intake ports near the carb.
              Nice size Caille. Just needs the nonstock paint job removed.
              #249978
              PM T2
                if its ID’d as an SR, it may be the Motorgo version of the Caille model 30. I’ve seen at least three of those motors identified with the SR prefix and they were all decaled as Motorgo’s
                Hope this helps.
                Best,
                PM T2
                #249996
                doug-secor
                  It is indeed a Motogo Senior. Motogo sold them in 1929 and it is exactly the same as the 1928 Caille Model 30 Racer except for the decal and rope sheave.
                  https://www.cailleoutboards.com/model-30/index.html
                  -Doug
