Home Forum Ask A Member Motor Value?
  • #229354
    swamp yankee
      Wondering what I should ask for a price for the now running jw-22, comes with a โ€œ59โ€ parts motor thats now missing the prop and some screws, its carb was full of powdered fuel and It seemed seized, but the head was good. Fuel tank and the rest of the parts all look pretty good. I couldnโ€™t quite get the 59 face plate to work on the 67, thats the only thing missing on the running motor, did seem to function fine when I finally got her done. Need to build up the kitty to get a boat for spring.
      #229363
        I have pick-up some between 40-70$ CDN…. with a second PARTS one which may be fixed …. my max for the 2 would be 100$ cdn if compressions are good (75+)
        small JW trollers are in good demand in fresh water country and they replace a good set of oars/paddles ๐Ÿ™‚ in case the bigger engine fails
        Joining AOMCI has priviledges ๐Ÿ™‚
        • This reply was modified 5 years, 1 month ago by JACQUES.
        #229370
        swamp yankee
          I was a bit concerned about the 24:1 mix these days, most of the fresh water bodies near me are not very large, figured they might get banned at some point the way the energy sector and climate is moving.
          #229373
            • This reply was modified 5 years, 1 month ago by Tubs.
            #229382
            swamp yankee
              Looks like an interesting product, might have to look into that, those seem to run nice
              #229439
              outbdnut2
                I’ve heard a few lakes have banned 2 stroke motors, but I don’t think we will see much more of that because most people (non-collectors) are updating to 4-stroke anyway. I see fewer 2-strokes out on my lake every year (except at my dock!). Your JW uses so little gas that pollution of the water from the oil should be insignificant.
                One of the most notable lakes to ban 2-strokes is Lake Tahoe in Nevada. When they were banned, the water patrol continued to use their (new at the time) Evinrude e-tec 2 strokes. I don’t know if they are still in use today.
                  I his my understanding that ETEC 2 strokes have been cleaner than 4 strokes when you consider some folks dumping their annual 4 stroke oil changes in sewers and nature..
                  ETEC’s burning bio XD-100 met EPA standards long time ago back in 2005
                  Unfortunately the 4 stroke Voodoo’S spoke louder and the 2 strokes
                  different strokes for different folks .. they say ๐Ÿ™‚
                  #229462
                  swamp yankee
                    I also heard heard the etecs burned hardly any oil, no first hand experience with those though. I did have a newer tohatsu 6 4stroke on my sailboat and I was not a fan
                    • This reply was modified 5 years, 1 month ago by swamp yankee.
                    #229471
                      Just doing some math here and 3 oz. of oil to a 128 oz. US gallon gives a fuel mix ratio of 42.6:1. That seems like a pretty lean oil ratio to use in a sleeve bearing motor which originally called for 16:1 or 24:1 mix depending on which manual you read. 3 oz. to an old 160 oz. Imperial gallon would be scarier yet at 53.3:1, which is pretty close to what modern high speed, high powered outboards use.
                      #229474
                        ETECS do burn bio oil xd-100 but…my 75HP used maybe 600 hrs in 15 years has not finished it’s 2nd gallon of oil ….. maybe it’s 3rd gallon but no more
                        it mixes a small portion in the gas feed but I believe it is mostly to protect injectors (3) and to prevent carbon build up
                        exhaust ports are always closed when fuel is injected so no unburnt fuel goes out the window (like old 2 strokes)
