Home › Forum › Ask A Member › Muggyweld die cast soldering rod
- This topic has 13 replies, 8 voices, and was last updated 5 years, 1 month ago by
Tubs.
January 19, 2021 at 10:51 am #228152
Has anyone used the brand MuggyWeld soldering rod for die cast? It is one of the few that advertises all the types metals the solder works with. It is very low temp and might be ideal for our hobby. The kits are pricey at about $100, but the demonstrations indicate it works.
Feedback??
George
January 19, 2021 at 1:47 pm #228165Here’s a good video about them. I don’t think Muggyweld is in this though.
January 19, 2021 at 4:21 pm #228174Harbor freight sells similar and has very good review.
https://www.harborfreight.com/8-piece-low-temperature-aluminum-welding-rods-44810.html
https://youtu.be/zE1P5Mhn_GQJanuary 19, 2021 at 6:36 pm #228188I have tried it , not impressed, ok I guess for something not critical, but not something I would want to use on a outboard where when it fails, your going to paddle or swim home. Just my 2 cents.
January 19, 2021 at 10:33 pm #228218I don’t know about the Muggy Weld stuff, but assume that it’s the same as the “how too” video… the pop can welding demo. I have used this rod to make several repairs , some rather structural. Understand that this rod is basically zinc. It’s significantly harder than aluminum and after a short while the color does not match alum, it’s darker grey. It takes practice… heat control and cleanliness are the secrets to success. Clean all parts well, I keep a dedicated stainless steel wire brush just for this work… CLEAN. .It’s fun to play with, and practice. The materials are inexpensive.. proficiency will prove handy.
January 20, 2021 at 11:33 am #228252Muggy Weld is an American company and their product is a bit different. They use a separate flux and the temp required is much less than the other products. They advertise it can be used for diecast, where the cheaper stuff doesn’t state that. Their kit is close to $100, which if it does what it is supposed to do, is worth it. I’ve got a American Swiss mag on a 1914 Wisconsin that the cam lever is missing due to breakage. I’ve fabricated an aluminum replacement but JB Weld wouldn’t stick to the die cast base.
I think I’m going to splurge and do some tests on some old scrap carbs to see how it does and I’ll report on the success or failure.
George
January 20, 2021 at 7:40 pm #228324George, please keep us informed as to how it works out.
January 20, 2021 at 10:21 pm #228337Pretty sure that someone on the forum has tried these type rods. Maybe Tubs or Mumbles.
January 20, 2021 at 10:48 pm #228342I’ll have to get some of that next time I go to my local Harbor Freight store and play around with it. On larger pieces, has anyone tried a MAPP gas torch?
DaveJanuary 21, 2021 at 10:49 am #228366I’ll have to get some of that next time I go to my local Harbor Freight store and play around with it. On larger pieces, has anyone tried a MAPP gas torch?
This reply was modified 5 years, 1 month ago by
Tubs.
