Home Forum Ask A Member Must-Do Items Before Trying to Start a ’57 ?
  • #81933
    lindy46
      My 1957 Lark (basically the same motor) ran about 120psi on both cylinders.
      #81936
      mas
        Yes…low pressure numbers.
        The rings may be a little sticky and/or the cylinders may be very dry.
        I’d lube up the cylinders a tad with fogging oil as you mentioned.
        If you can get it to run, those compression numbers are likely to go up.
        Also, it’s a possibility the compression relief valves are not fully seated and the PO removed the lever to remedy…but without success????
        Mas
        #81951
        markpj23
          quote Chris_P:
          ..Did you use electric starter to test?
          Yes electric starter
          #82087
          lloyd
            80 psi IS way too low for that motor. Should be about 125 as I recall. Compression relief valves may be stuck open or leaking ?
