Home Forum Ask A Member Neptune lower unit oil seals
  • #8392
    thecoinbox
      Can’t find a replacement for a NOK 1.1 shaft oil seal. The seal measures 1/2"od 3/8"id 3/16"tall.
      I’ve tried numerous sources and they all say NO.
      What to do when a critical part is not available?
      #65768
        Think you could make a quad ring stay in there?
        https://www.mcmaster.com/#90025K137
        #65770
        mikesea
          Did you try National? Look at the size charts, call Federal-Mogul Tech in St. Louis ask for Steve if he is still there he will look for you.
          One tip I have found working with seals for 10 years is they might be the same color but they are not the same quality and fit.
          If trying to use a valve stem seal shy away from USA seals. You could look at Viton o-rings.
          Good Luck,
          Mike
