Home Forum Ask A Member New oil seal leaking
  • #8246
    stanley
      I just replaced the upper seal in 1957 Johnson FD.I just got the motor and could see it had been leaking.After installing the new seal I decided to squirt a little oil on it.Gave it a few turns and air bubbles appeared.Whats going on?
      #64999
        Perhaps there is damage or wear on the crank mating surface?
        #65001
        stanley
          That’s what I thought,just wanted a second opinion.
          #65008
            Mike it to check groovey wear pattern, might need a Speedi-collar….bearing slop?
            #65010
            stanley
              Doesn’t seem to have bearing slop.What’s a Speedi-collar?
              #65012
              JOSEPH BRINCAT
                A Speedi -collar or by some other name is a very thin stainless steel sleeve that press fits over the shaft and provides a new clean surface for the seal lip to ride on. Available at your friendly neighborhood bearing store.
                #65067
                rudderless
                  Install a new seal just short of the wear groove if you can on that motor.
