Home Forum Ask A Member Nice TN27 $50 – winter project
  • #67298
      Thanks copied everytyhing ! … parts prices are good 🙂
      #67301
      seakaye12
        I always enjoy those parts lists that come with prices! To think that prices were considered stable enough to do that. The universal magneto coil was $7.50…..quite a bit considering how long ago that was.
        #67341
        hag
          Well, more serious then I thought. The head bolts are not missing, they are broken off. Yup 5 of them, not sure I can dig out all of them!
          I’ll try Doug Penn to see if he has crankcase, but any other suggestions?
          #67343
            depends how much you want to spend in light of what you found. 5 broken bolts ….hum …time to fold
            #67352
            jerry-ahrens
              Before you put much work into it, I would suggest doing a compression check. If I remember correctly, around 75 psi and up is good. 85 is better. Compression under 70, and you will have a hard starting motor, as well as one that won’t idle down.
              I v’e only found one TN with a good powerhead over the years, and many that are worn out… due to high hours, or running them 50/1.
