Home Forum Ask A Member not an oldy but …I need info on this part
  • #242827
      I am fixing up a 94 3.3hp Evinrude from HONG KONG…H3RERM
      looking for the wrap around cowl starboard side part# 0115619 Evinrude blue like an ETEC blue ….with the side clip parts
      looked everywhere and zilch ….
      • This topic was modified 4 years, 8 months ago by JACQUES.
      #242894
        For what it’s worth (nothing) I have been finding parts for all the Asian-origin, badge-engineered small engines to be real hard to come by and/or very expensive. At best, you sometimes see that stuff from the United Kingdom; but the shipping is a killer.
        #243221
          got it decent looking and holding up ok after fixing several cracks
          1. drilled a few 1/16 holes each side of the cracks and key crack points and stitched it with extra thin SS wire from the hobby shop
          2- Tried several plastic glues on PP plastic and got nowhere (bondic.. Plastic Welder) πŸ™ They had work on my 75hp ETEC lower cowl bolt cracks but not this 3.3hp plastic stuff)
          3- Inside the cowl I installed 2-3 layers common sticky fiberglass drywall tape over major cracks
          4- Covered up the taped areas with 2-3 layers of Lepage contact glue (white stuff and dries clear) and HOLDS GREAT on the polypropylene plastic cowl
          5 – Sprayed everything with my can of ETEC blue paint
          6- rebolted everything up …holds up fine and not to bad looking
          7- the side latch (missing) and UNAVAILBALE was replaced with a 1/8 hole hole in the upper cowl and a…blue tye wrap πŸ™‚
          • This reply was modified 4 years, 8 months ago by JACQUES.
          #244256
          Monte NZ
            International Member
            I have been restoring a 1991 Hong Kong 2.3hp Evinrude (which I think is very similar to your 3.3hp) and have used J B Weld, together with fine stainless steel wire, to repair the hood……;.;seems to be holding so far.
            Monte NZ
            #244257
              Gotta love it!!! All that high tech work and finished up with the bottom line…..a blue tye wrap!!! This is great stuff.
              #244260
                well I was disappointed to … the tye wrap blue does not match Evinrude E-TEC blue but it is holding up fine. πŸ™‚
                if it ever breaks, I’ll go with fine SS wire from the hobby shop..and dab it blue E-TEC .
                the owner did not want to install the available & expensive eqv. Johnson part…repainted blue….just for the kid’s boat.
