Home Forum Ask A Member OMC folding motors
  • #314278
    Randy White, Sr
      Have searched for this in various ways on this forum  but found very little info.   Found this 1967  Johnson JHF22C  3 hp folding motor in younger son’s barn.   Trying to get background info on it, such as years they were made, how many produced per year, rarity, etc.   This one turns over and has compression but didn’t have gauge with me, so don’t know how much per cyl. Will appreciate any info.  TIA
      #314293
        These are not too rare, finding one with a good case that isn’t damaged is rare.  You must be very careful not to damage the tip of the gearcase or the unit will not lock in the folded position.  Yours looks to be a 1967 Johnson with the 90 degree higher thrust gearcase.  The biggest concern is the condition of the fuel tank, make sure it isn’t rusted or fouled inside.  Going through the ignition, fuel systems, impeller replacement is usually all they need to become reliable daily runners.  These engines don’t have much compression, you will only see about 70PSI, which is normal.
        I don’t know what other questions you have….
