Home Forum Ask A Member OMC tach 122923
  • #10799
    amuller
      Picked this up at Tomahawk. Can’t remember if I paid $1 or $2 for it.
      In any case there are four leads: blue, black, gray, and purple, and a pulse/rev dial with settings of H, 2,3, 4, and 6.
      Can anyone point me to a data sheet for this, or tell me which wire goes where?
      And will this tach work with an early 70s CI ignition? I vaguely recall that there was a special tach for those. I also think there is a gray wire from magic box, not otherwise used, that might be for the tach.
      Thanks for any help.
      #80886
        Well the wires are simple enough. Blue to running lights (dial illumination) Black ground, gray pulse signal, purple switched 12V. I think it might be an universal tach, but that’s guessing.
        #80912
          Early seventies should have a rectifier in the charging system, if I remember right. You would hook up the wires as Frank said, hooking the gray wire to one of the yellow wires at the rectifier, preferably the one with a gray tracer. I am going on memory but I believe you’d put the switch on 6. Then the tach should work, providing that the charging system is working to start with.
