Home Forum Ask A Member Paint match
  • #178060
    yooperrigged
      Does anyone know of a duplicolor, rustoleum, or krylon paint color that would be a decent match for holiday bronze? I am swapping out a throttle arm that is blue. Thanks in advance.
      #178063
      David Bartlett
        Well, there are 3 different Holiday Bronze colors, depending on year. I have not found a close enough match for painting single parts, but even if you got the right paint, it probably won’t match either due to fading.
        Didn’t really answer your question though, did I?
        David Bartlett
        #178078
        yooperrigged
          Well the motor is a cd14 which I believe is a ’57. I guess any holiday bronze is better than Evinrude blue.
          #178128
          JOHN D.
            I have used Duplicolor #BFM0344 Toreador red metalic. May not quite match but i have painted an 18hp 1957 Johnson with it with good results.
            #178156
              Yeah, that sounds familiar. I think that’s what I probably used.
              #178199
              olcah
                I used that toreador red metallic on a hood recently also. To me It is a darker more purple color than holiday bronze but it does look nice.
                #178228
                olcah
                  Here is the toreador red. You be the judge.
                  • This reply was modified 6 years, 9 months ago by olcah.
                  #178236
                  yooperrigged
                    Certainly looks good enough for me. Thank you all!
