Home › Forum › Ask A Member › photo of boat-side connector for OMC 18/20/25 electric start?
- This topic has 6 replies, 4 voices, and was last updated 8 years, 5 months ago by
Anonymous.
April 25, 2016 at 10:38 pm #4132
I’m trying to figure out how to make a harness for my 1959 electric start Evinrude Fastwin.
Can anyone point me to (or post!) a photo of the ORIGINAL boat side connector for an OMC 18/20/25 HP electric start?
I’d been working on the assumption that it’s similar in shape to the englne side (which tapers), but I just realized I could be wrong!
The 1959 has 5 wires (ground, start, choke, and 2 magneto), I seem to recall some newer versions had another pin(?), and that older versions didn’t have the choke pin….. But I’m ASSuming (again) they all had the same shape on the outside!!!
Thanks in advance
Phil
(Yankee Chapter)April 25, 2016 at 10:47 pm #35496http://www.nymarine.ca/18hpesharness1958.jpg
HERE YOU GOApril 25, 2016 at 10:51 pm #35497Anonymous
quote wannabe outboard guy:http://www.nymarine.ca/18hpesharness1958.jpg
HERE YOU GOThat’s a modern reproduction….. I was wondering if they copied an original, or made it up.
Everytime I think "Why don’t I just give in and purchase the North York harness?"
I look at the price, and then I’m back to thinking about how to make my own!!!I realized the later harness extra pin goes to the start solenoid (moved under the hood)
April 25, 2016 at 11:14 pm #35500I made my own when I saw the price of that one. Mine has no connector. It’s wired directly under the hood. That’s where I mounted the solenoid as well. It was not hard to wire it for a push button start, choke and kill buttons.
October 26, 2017 at 3:01 pm #66641If someone can lend me a connector, I can measure and model in 3D then get some 3D printed
I am looking for a harness for a 1959 Fastwin 18 & don’t think I want to pay the price from NYMarine. I would rather make my own
October 26, 2017 at 3:27 pm #66642If you post a "Wanted" ad on the classified board here, someone will likely have an original plug with harness at a reasonable price. It may also have the key ignition switch and a key with it along with the solenoid box. Give it a try – ads are free.
I’d be wary of a 3D-printed connector – there is a lot of vibration and flexing there and 3D print material may not hold up. Also – making and fitting contacts into a 3-D printed connector will likely be a real challenge.
If you live anywhere near Minneapolis area, you can drive over and look at the connector and harness on my boats.
DaveOctober 26, 2017 at 3:46 pm #66643Anonymous
I’m the one who started this thread. Here’s what I came up with:
viewtopic.php?f=19&t=9182
I had the male (engine side). For the female (boat side) I used soft copper (refrigeration) tubing for the contacts, and encased it in black epoxy putty used for swimming pool repair. I tried using the male side to make a mold, but ended up shaping it mostly by hand.
