Home › Forum › Ask A Member › PO 15 ignition plate removal
- This topic has 9 replies, 4 voices, and was last updated 3 years, 10 months ago by
Buccaneer.
May 21, 2022 at 3:31 pm #260197
Hello fellow members, I’m taking a Johnson PO 15 apart and my ignition plate is being difficult. I have heated it and tapped it at various places near the crankshaft boss but to no avail. I have attached a photo with a pencil pointing to a recessed slotted ring and I don’t know how this comes out…..do you need a special tool?….or is there an optional method. Please give me some advice……just tried to load picture…..won’t let me! says file is too big.
May 21, 2022 at 6:42 pm #260207May 22, 2022 at 6:08 am #260263Yes, clamping bolt is off, now how did you get that washer sitting on the other side off?
May 22, 2022 at 8:39 am #260271May 22, 2022 at 9:38 am #260283Interesting… can you email the photo to manleyt at verizon dot net (convert this to standard format) so I can edit and post it?
Tom
May 22, 2022 at 10:57 am #260290On your smartphone…..if you can do a “screenshot” of your original picture….the resulting file may well be small enough to post here.
May 22, 2022 at 3:22 pm #260323OK gentlemen, I finally figured this out and was able to resize photo and post….hope this picture helps.
May 22, 2022 at 6:47 pm #260329I believe that split washer is an oil slinger of sorts. That doesn’t need to come
out in order to pull the mag plate off.
Here’s a photo of my powerhead, sans mag plate, and you can see the split washer
in place.Prepare to be boarded!
May 23, 2022 at 8:27 am #260365Well, I guess that rusty junk of mine had me fooled into thinking the top part came out with the mag plate. Your power head looks great. Let me go back and apply more heat and force and see what happens!
May 23, 2022 at 6:52 pm #260395I assume if the mag plate doesn’t pull up, then it’s not swiveling back and forth either?
Patience wins the battle. Gentle heat and lots of pee oil.
With the clamping bolt removed, you can use a big screwdriver in the slot for leverage,
and it may slightly open the hole up to get the mag plate moving.Prepare to be boarded!
