Home Forum Ask A Member pressure & vacum testing
  • #189310
      I decided to experiment for a few $$$ ($20& free shipping) ) ………. ordered a car AC hose and I will add the gearcase adapter to pressure test
      the dial is good for pressure and vacum tests using a pressurized air source or vacum testing using a vacum source like a small pump to purge brake lines
      I’ll test all this when the stuff arrives by mail in january
      https://www.amazon.ca/gp/product/B07K4Z5KFL/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
      • This topic was modified 6 years, 2 months ago by JACQUES.
      #189360
        update…. I cancelled the above as I found a dual purpose pressure/vacum hand pump seen on a utube * and decided to gift myself 🙂
        https://www.amazon.ca/dp/B0727Z9B79/ref=pe_3034960_233709270_TE_item
        * https://www.youtube.com/watch?v=lnhZFn5gkG4
        • This reply was modified 6 years, 2 months ago by JACQUES.
        #189406
          Looks like overkill to me….And, you must be very careful about using devices connected to a compressed air source that could easily over pressurize the gearcase overwhelming/destroying otherwise good seals/gaskets/orings.
          #189417
          RICHARD A. WHITE
            I use a bicycle pump for pressure and a brake bleeder kit for vacuum testing….very nice, those small bicycle pumps from Walmart work very well
            classicomctools@gmail.com
            #189419
              I actually cancelled that AC charge hose and ordered a manual purge pump which does pressure and vacum test for 49$ CDN no shipping but….my post when POOF…..????
              here is a picture which short circuits the POOFING edits on this new site of ours
              I also poste a good u-tube on it’s use but POOF with the other one
