Home Forum Ask A Member Prop for 1958 evinrude 5.5
  • #11356
    mrhtx21
      Hoping someone might be able to turn me onto a prop that will fit my 1958 evinrude 5.5 fisherman 5516 as my original finally broke a blade any leads on one reasonably priced would be greatly appreciated
      #83571
        Well, that part number is: 376968
        Be very careful, the prop for the 7.5hp will fit, but is the wrong prop. It is very easy to confuse the props, they look pretty much identical, but the 7.5hp prop has a little more pitch….
        I looked on ebay, there was one, but it was priced way too high.
        You might try the classified ads here….
        #83577
        retiredoz
          Michigan lists 012060 (376968) and 012067 for that motor..
          #83578
          retiredoz
            seems excessive..
            https://www.ebay.com/itm/MICHIGAN-PROP- … Swf-xZlz4I
            #83581
              mrhtx21, you have a PM (private message)
              #83603
              outbdnut2
                If you are looking at buying a new one, here is one source with a selection – you will want one the 6-1/2 or 7-1/2 inch pitch for your 5-1/2 – note the 2 and 3 blade column:
                http://propcopropellers.com/evinrude—johnson.html
