Home › Forum › Ask A Member › Pull Rope
Where is a good place to but new pull rope… old style?
If you want the type with the metal embedded in it, don’t think that is possible. Normal 3/16" or 5/32 is easy. Available at your local dealer, online, etc…
Local lawnmower shop has every diameter I’ve ever needed. Larry
Good idea!
THANKS!
Ace hardware has a tight knit rope in the bulk that is called starter cord. It works quite well. Ed
Ed, I too have used Ace rope without fail.
Check your PM…
OK
