Home Forum Ask A Member Question for the Mercury guys
  • #299785
    labrador-guy
      What kind of grease should I be using on the shift cam on  1956 mark 55?  It takes a lot of muscle to get’er into reverse.  I been using regular marine grease.  Once it’s in gear it works like it should.  Gear oil is OK.  Maybe it needs lubraplate?
      dale
      get’em wet….don’t let’em set
      #299792
        I use john deer corn head grease. best
        #299795
        labrador-guy
          Thanks dave, gonna try that!
          dale
          #299797
            grease the reverse locks and cam also.
            #299808
            labrador-guy
              Ya my gear case is fine!  It is the reverse cam that I am talking about.   I put some corn  head grease in that cam pocket and worked the L out of it.  It is still plenty stiff.   Maybe I should start lifting weights!
              dale
              #299813
                DROP THE LOWWER AND CLEAN THE CAMS AND GREASE THEM. MAKE SURE THE ROD AND REVERSE LOCKS ARE MOVIBG EASILY.
                #299849
                  Believe Dave!  He has helped me on many Mercury projects!
                  #299851
                  labrador-guy
                    Yup dave knows his beans!
                    dale
