Home Forum Ask A Member Refilling Gear Lube on JW-10
  • #182778
    Yellowstone
      So I messed while putting a new impeller on and loosened the drive shaft from the pinion it sits in. I couldn’t get it to slide back into place with the gear lube in, so I drained that and then tried and was successful after lots of playing Yahtzee with the lower unit. Now, my question is, do I refill the lube from the top opening that says Refill with Hypoid Oil? Or do I use the lower opening that says Drain. It seems like a no brainer given the opening descriptions and while I can’t find specific text in the 1964 Johnson Manual, it does show the lube being put into the top opening in a photograph. The only reason I ask is other motors I read lots of other articles saying you should put the lube in from the bottom to avoid air bubbles. Thanks!
      #182779
        Proper way is put it in from the bottom. However, the 3hp is kind of unique in that you can drizzle it in slowly from the top. Your choice.
        #182803
        Yellowstone
          Thanks. I figured it looked kind of unique to the rest of the models in the service manual. This has been a learning process but a fun and rewarding one. I’m learning all the parts of the motor for sure.
          #182824
          lindy46
            I fill from the bottom until it overflows from the top.
            #182845
            Yellowstone
              Thanks. I plan to use the lower opening to fill today so I can finish checking the points and getting ready to put the flywheel back on. Once the new torque wrench arrives.
