Home Forum Ask A Member Repairing cracked solder joints in 1922 Elto Light twin tank.
  • #60450
      I’m not so sure one could get the tank hot enough to solder
      if it’s full of water… can you?
        quote Buccaneer:
        No. Water would be turning to steam
        before the solder ever melts. Wash out
        the inside of the tank several times with
        the water base dirt and grease remover.
        Re-melt solder with a heat gun.
        #60465
        PugetSoundBoater
          quote Buccaneer:
          good point .I did use the water method many years ago when brazing on a still tank.
          Robbie Robertson
          #60475
            Just the right mix is all it takes. Add a little dishsoap to the water, then very carefully wipe the torch past the cap opening full of water, drain & repeat. Then fix the tank, but get it very clean & a little flux too boot. A dose of acetone afterwards to remove any moisture.
            Me, I would be the nut to desolder it to clean the inside too, just how I’m wired,
            #60639
            Monte NZ
              International Member
              Thanks again all of you for your helpful suggestions.
              Your suggestion Jeff, to desolder the tank did pass through my mind, but I think I will just try repairing the two leaks at this stage.
              MonteNZ
