Home Forum Ask A Member Restoration of 1964 Johnson JH 19A
  • #246697
    Monte NZ
      International Member
      Hi All.
      I have to make an exhaust manifold and two power head to trunk gaskets and was wondering if it is ok to laminate to sections of .5 mil gasket material ( the thickness of the original gasket was 1mil.) If that idea is ok, should I put any sealer between the laminations and would shellak be ok .
      Thanks for any help
      Monte NZ
      #246726
        These gaskets are available NOS. But, perhaps finding them overseas is difficult.
        #246732
        Monte NZ
          Hi fleetwin. Unfortunately we are still in lockdown with Covid, so I thought I might be able to speed up the restoration.
          Thanks for your reply.
          Monte NZ
          #246742
            As long as the sealing surfaces are clean and flat, I don’t see why a 1mm (1/16″) gasket wouldn’t work. A light coating of Perfect Seal would help.
            #246918
            Monte NZ
              Thanks Mumbles for your suggestion………sounds good…….I have some Perfect Seal.
              Thanks again
              Monte NZ
