Home Forum Ask A Member SAE 60 Oil
  • #2148
      Could this oil be used in the pre-war motors which call for SAE 40 if it was blended with TCW III?
      http://www.usedvictoria.com/classified- … T_14649053
      Being racing oil, it would have a high zinc content and I’m thinking it would help to seal the early motors with rotary valves on the crank.
      #21180
      cajuncook1
        Jim, a couple of years back I asked a similar question, but I made reference to the SAE 40 and TCW3 oil. I had a couple of experienced members state that they like to mix 1/2 and 1/2 of the TWC3 and SAE 40 oil at the factory recommended ratio. They felt the improved lubrication of the TWC3 oil and the increased viscosity of SAE 40 oil provided excellent lubrication, provided adequate crankcase sealing and aided in improved compression.
        I wish I could remember the 2 members names for reference. All that information went down with the old boards. 🙁
        #21212
        aquasonic
          I have always wondered how motors that were recommended for SAE 40 were considered to be OK for TCW-3. There is clearly a difference in the viscosity between these two.
          Improvise-Adapt-Overcome
          #21246
          jim-moffatt
            Nowherre i n the posts is the presence of detergents i n the oil mentioned.
            Be careful that the oil is not the detergent type. Detergent oils will not mix with gas well and do not work in 2-cycle engines. That is why all modern oils are labeled for 2-cycle use. Plain non-detergent sae 30-40-50-60 will work OK.
            #21314
            steveh
              This is another one of those topics which was discussed extensively but lost when the boards went down. What I recall from that discussion was that the modern TCW-3 does a better job at lubrication and burns more completely than the SAE grades. However, the higher viscosity of the SAE grades provided better sealing around the piston rings yielding higher compression and better idling. There were also some comments about high viscosity 2-cycle oils for use in older airplanes that might work in our outboards…
              #21315
              melugin
                I got a case of 40wt oil for free and am now using about 1/3 of it in each amount of oil mix for my pre-war motors. I also blend in TCW II, III, and synthetic. Motors running fine.
                #21323
                Casey Lynn
                  For my bigger opposed engines I will run a combination of Aircraft engine oil and TCW3 for the reasons stated already.
                  #21422
                    Does aviation oil have a high detergent content? I’ve heard of it being used before and being for air cooled motors, local guys here used to use it in their Harleys.
                    #21428
                    Casey Lynn
                      The short answer is….NO!
                      Here is a longer answer.
                      http://www.swaviator.com/html/issueja02/Hangar7802.html
                      #21429
                      cajuncook1
                        Thanks for the link Pappy!
                        Cheers,
                        Cajun
