I have found to remove the housing from it’s home, heat the aluminum a little. Scott made motors, they used something like contact cement in the base. I’ve bent a few inserts till I used a little heat to melt the cement & slightly expand the aluminum. Straight leg Scott’s have a seal under the impeller housing. Tom do the swept legs have a seal there too?
Not to hack but try a Mark 28 impeller change, Total tear down & pound it out from where the powerhead was! š® Frank knows!!
