Home › Forum › Ask A Member › Screws too small
- This topic has 22 replies, 7 voices, and was last updated 5 years, 1 month ago by
DAVID.
December 29, 2020 at 10:59 am #226259
I bought an exhaust tube that goes into the exhaust of a J= (after market). It came with the 2 screws, but they are too small for the holes in the exhaust. I don’t want to drill the holes larger in the tube to use the right size of screws. What can I use to put into the exhaust holes that will accept the screws that came with the tube?
Thanks, RobertDecember 29, 2020 at 1:08 pm #226273Say what? Are you asking for some sort of a thread reducer bushing? Let’s start over with some better information on what exactly it is you are working on.
December 30, 2020 at 7:25 am #226354I think I know what you’re talking about,but a picture sure would help
December 30, 2020 at 10:24 am #226388
This reply was modified 5 years, 1 month ago by
Tubs.
December 30, 2020 at 11:51 am #226399You are likely correct , Tubs. Probably a #12 screw hole and they gave him the common #10 . I keep handy my chart of old screw sizes for just this kinda’ question.
Some of the old American Standard screw sizes that one is likely to encounter on old machinery…Note that several are dangerously (deceptively) close to modern common sizes.#12 = .216 inch dia.
#14 = .242
#16 = .268
#18 = .295
#20 = .321
#22 = .347Joe B
December 30, 2020 at 12:26 pm #226402
December 30, 2020 at 5:50 pm #226447Tubs, I call those an American Standard #16 -20. Understand that the actual measured diameter on a commercial screw is typically a few thousands smaller than the nominal size.
PS, and the #16 screws came in pitches 16, 18, and 20 TPI
JOSEPH BRINCAT.
December 30, 2020 at 9:29 pm #226491.
This reply was modified 5 years ago by
Tubs.
December 30, 2020 at 11:15 pm #226499Mc Master Carr has lock washers for cap screws… from size #2 thru 1 -1.2″ . Also maybe check metric lock washers, they typically have smaller outside diameters than the US ones.
JOSEPH BRINCAT.
December 31, 2020 at 12:45 am #226504 -
