Home Forum Ask A Member Sea King 1951 5hp screwed up
  • #182975
    jimk
      Not the motor as much as me! I got it running and did the waterpump but it wouldn’t go to neutral. I took the lower unit back off and looked to see if I could figure out what was wrong and thought I had it. The little lever at the end of the cable looked as if it was bent so I tried to straighten it and broke it. Does anyone know where I can find a replacememt? It is part number 29, 302-338 Lever-clutch on the lower unit gear case parts list. After I broke it I looked at the part on the parts list and it was made that way. I should have looked before as it shows the bend in it. Thanks, Jim
      #182986
        They are $16.00 at Marineengines.com, If some one doesn’t have a good used one . . .
        #183005
          I have one that I was going to offer to you for the postage. But I just went out to lay hands on it and found that it is broken too. Looks like you aren’t the first guy that tried to straighten one.
          #183007
          jimk
            That makes me feel a bit better. Sometimes it just doesn’t pay to try and do something without knowing what you are doing LOL. Hope to come up with a good used one but I will order a new if I end up having to. Surprised that Marine engines has one! I had to go look at it on there and yup, that shows the bend that I “tried” to fix.
