Home Forum Ask A Member Shock Absorber Welding?
  • #216386
    drifter
      Have just experienced – again – a shock absorber helical spring break, which, in turn, ruined the drive shaft housing by severely warping it, I’m wondering if it is a good idea to weld a good absorber before the spring breaks? I have welded broken absorbers before but, for me, it’s difficult to get the pieces perfectly true. I always run a brass shear pin in place of the drive pin.
      Your thoughts?
      Thanks
      #216387
      labrador-guy
        The 5 1/2 n 7 1/2 Omc motors are not a high speed high power motors. That shaft just needs to be close to straight. I wouldn’t worry about it. Just tack it in a few spots and Giverthegas!
        JMHO
        dale
        #216428
          I fabricated a sleeve to go in the absorber in place of the spring and locked it in there with some High-Strength Locktite. That was several years ago and it is straight and hasn’t slipped yet. Hard part is getting both halves of the busted spring out. I’m thinking it would be easier to get out before it breaks.
          • This reply was modified 5 years, 6 months ago by frankr.
          #216488
          drifter
            Thanks for the tips.
            Frank, any tips on removing that pesky spring????
            #216494
              Matter of fact, I just came in from my shop. I have one of those absorbers “somewhere”, but can’t find it. My intention was to see how difficult it is to take one apart. I’ll report back, if I find one.
