Home Forum Ask A Member Silicon grease packet???
  • #278526
    TimJacobs
      What is the small silicon grease packet that comes with a new set of points/condenser used for???
      #278527
      lindy46
        Should also be a felt pad to lubricate the cam. The packet contains the lubricant for the pad.
        #278529
        TimJacobs
          That makes sense. The pad seemed to already have grease in it but it makes sense to add some. Is this a maintenance issue where you pull the flywheel occasionally and add some grease to the pad?
          #278531
          lindy46
            If the pad is already lubricated, don’t put more lubricant on it. Save the capsule for later. I wouldn’t remove the flywheel very often just to add lubricant. You may have a port on top of the flywheel to access the points.  You may be able to add lubricant through that port. I just add a few drops of 3-in-1 oil to the felt pad whenever I’m in there. Don’t over -lubricate.
            #278546
              The felt pad is for oil. The grease  would be placed on the back side of the fiber block of the points that runs on the cam. As it wears grease is  deposited on the cam lubricating and extending the life of the fiber block. As you have a felt pad you can discard the grease.           Tubs
              #278548
                you can add some on the point pivot shaft
                #278549
                  I heard that you are supposed to swallow that pill 1/2 hour before replacing the points.  That will dilate your eyeballs so you can set the points gap without a feeler gauge.
                  #278551
                    FR… today  some would take you to your word and  swallow it…and still complain the timing was off !!  then sue !    funny nonetheless !
                    #278552
                      It’s faster acting if  inserted at the other end.         Tubs
                      #278573
                        Ive  washed the pad with dishsoap to get it clean & relube, but I like Tubs & Franks suggestions better.
