Home Forum Ask A Member Speeditwin paint
  • #178206
    Samuel Phelps
      How should I match the paint to original color ? Is there an OMC number that is known ?
      Or just maybe take the tank and try and match the unfaded shade on the underside .
      Paint type suggestions ?
      #178210
      outbdnut2
        The Speeditwin name was used for several years, and the paint color varied with the year. What year or model number do you have?…Then someone can recommend.
        Samuel Phelps
          I was told once that it was a 1949 .
          Model # 6039-26688
          #178221
          rvdriver
            Reprotint makes the paint. google it and you should be able to find your paint.
            #178223
            David Bartlett
              Dull Aluminum paint on that one.
              David Bartlett
              #178556
              Samuel Phelps
                Ok , I assume if I take any aluminum down to bare metal I would need to use self etching primer first . Correct ?
                What do you guys use to clean the oil and crud off the motor. I’ve painted a few boats here and there but haven’t painted a motor yet ..
                Any special prep work I need to do ?
