Home Forum Ask A Member Stator lead identification problem
  • #10758
    johnyrude200
      I have run into an issue with a replacement stator that I purchased from CDI.
      The yellow, yellow/grey leads are usually labeled to figure out which terminals to connect to the rectifier appropriately. Well, both leads off this stator are yellow, and this is new out of the box.
      Is there a way to figure out which one is supposed to be connected to the yellow/grey, other than just chancing it by connecting everything, starting the motor, and seeing if the battery is charging?
      If this is connected in reverse, can this cause damage to components?
      #80707
        It’s alternating current at that point, so don’t think it makes a darn bit of difference. Apparently it doesn’t make a difference to CDI, either. In fact, I always wondered why one usually has the gray tracer, other than to remind a person that the tach, does, in fact, connect to one of them. I am sure the others will chime in with their input, too.
        #80709
        jerry-ahrens
          Bill is correct. CDI doesn’t add the extra tracer stripe on their yellow leads. Just hook em up and go. I would suggest keeping all packaging and instruction sheets, in case of the need for warranty… you may need them.
          #80710
            X3. It doesn’t make any difference. Except on some motors with voltage regulators where the regulator cutting in and out can cause erratic tachometer readings.
            #80712
            johnyrude200
              Thanks guys hope each of your summers have been filled with pleasant boating!
