Home Forum Ask A Member Substitute for 303122 filter bowl gasket?
  • #175292
    cron78
      Is there a good substitute fro the glass bowl gasket that doesn’t come in the carb kit? It’s silly that one isn’t included in the BRP carb kit! Wanting to get a ’58 10 horse back up and running for this weekend and I doubt I can get one in the mail by then.
      Thanks for any expert suggestions.
      #175299
      labrador-guy
        I use an “O” ring! If you can take the filter to you local hardware they should be able to fix you up!
        dale
        #175302
        cron78
          Roger that. Thanks.
          Dale
          #175338
          cron78
            Went to the local hardware store today (the one that the hurricane didn’t close) and found a #212 o-ring will fit the bill. 7/8″ ID and 1 1/8″ OD. Found out before that BRP quit making the actual 303122 gasket in 2015 and you have to get them from the dealers that BRP sourced the remainder gaskets to. I have that list of sources from my local ma & pa OMC repair shop if anyone needs it, but $0.56 beats about $13 shipped any day unless you have to have a correct gasket for resto.
            Dale
            #175354
            Geer Pyron
              Dale, Your reference to the hurricane clued me in that you must be the Dale I met at Yellow Jacket in April.
              True?
              Good if so.
              Did y’all get to see the varigated whistling duck after all?
              Ha!
              I replied to your other post about a carb needle.
              May as well tell you how I rigged the bowl gasket too.
              I just cut one out of a rubber washer. Like a big rubber fender washer from the Lowes.Traced the bowl onto it then just cut it out. I.ve had problems with o-rings distorting when they arent being squeezed from all sides.
              Anyhoo, isnt there a meet comming up in your neck of Florida soon?
              Geer
              JMGP
              #175365
              cron78
                Hey, Geer. Yes, that’s me. The o-rings I found fit nice and tight and pretty much fill the area so that they will only distort for a better fit and the glass bowl still fits well… And only 56 cents each. I looked at other gaskets that I could cut to fit, but that takes more talent than slipping in an o-ring.
                And, yes, we have a meet at Lake Talquin near Quincy, FL this weekend. That’s why I’m trying to get this motor back together.
                Dale
                #175395
                rmhxruss
                  Sierra 18-7123 is available. For 303122.
