Home Forum Ask A Member Tillotson Carb Brass Plugs
  • #257767
    geary
      Good call Greg,   Was going to suggest most lawnmower shops should be able to supply one ?
      #257776
        I looked in Machinery’s Handbook, and found tons of stuff, but brass
        fittings wasn’t one of them.
        It’s closer to 1/4″ pipe thread, but that has a different tpi, and is slightly
        larger OD than what came out of the carb.
        Good to know they come with kits if necessary, but I’d be happier
        coming up with a better way to make my own on the lathe.
        Thanks.
        retiredoz
          I’ve got a bunch of cadaver  MD carbs, if you need more plugs..
          #258013
            Thanks for the offer, and if I need any, I’ll know whose door to knock on!
            amuller
              For a  taper that short you should be able to use the compound and not worry about a taper attachment.
              Don’t know if it would help, but British Standard Pipe (also the metric standard) compares with USS like this for “1/4” sizes:
              TPI  US:18, BSP: 19
              Major diameter US: .540, BSP:  .518  (Not sure the diameter was measured the same way.)  The thread form is also different, BSP using a Whitworth-like form.
              Other equivalent sizes have similar differences.
              #258102
                I did turn the initial taper with the compound, but threading with it might be tricky!
                I suppose those carb fittings may have some kind of Brit thread, or metric perhaps.
                Hope to stumble upon more on brass carb fittings someday. Thanks.
