Home Forum Ask A Member TUBE BENDING
Viewing 10 posts - 11 through 20 (of 29 total)
  • #66996
      There is an alloy of 50% bismuth, 26.7% lead, 13.3% tin, and 10% cadmium by weight that was developed by Barnabas Wood in 1860. It has a melting point of 158 degrees Fahrenheit. Woods Metal has many uses. . . 🙄
      #66998
      lagrue
        Try freezing the pipe. Check about 3 mins into this vid. Vid is pertinent to tbis thread in a couple ways!
        https://youtu.be/G5LqrMcq1QE
        #67002
        amuller
          That is a pretty tight radius for that size tube. I think you will have trouble with anything other than a proper tub bender. I don’t know what you are making but have you considered making it up out of fittings? You can get return bends (180 deg) from a refrigeration supply house.
          #69012
            quote ratrodz:
            Anyone have good luck bending soft copper with spring benders? I have a 5/8 OD soft copper
            tube that I want to bend 180 degrees to a 2" radius. Should I try a 5/8" spring, I heard they get stuck, or 3/4"?
            Bob Huff
            #69015
            bob-d
              If anyone wants to pick up the spring set that Tubs recommends.
              https://www.ebay.com/itm/Spring-Tube-Be … 0305!US!-1
              I’m going to get a set, as I have also tried all of the other methods without success. The aluminum water lines on a 1929 Evinrude Fastwin were a killer. After most of an afternoon they still had a load of kinks.
              Bob D
              #69025
                Bob, What size is the tubing on your Fastwin
                and what are you using for replacement tubing?
                #69028
                stanley
                  Anyone know how the tubes were originally manufactured?
                  #69029
                  bob-d
                    Tubs, I used a 3/8” OD thin wall tubing I found on eBay. I looked for the link, but didn’t see that posting anymore. I could dig around through my receipts if you want to buy from the guy.
                    I’m almost embarrassed to post pictures of my tube bending expertise.
                    I even cracked the right one, and put some JB Weld on it…. geese what an armature I am.
                    Thought it would be ok with the low pressure application. Never got the motor to start, and put it on the back burner. Don’t even get me started on those bizarre end fittings that Evinrude used in the 20’s.
                    Bob D
                    bob-d
                      Meant to say amature, but maybe I am an armature as well!
                      #69032
                        Is the aluminum tubing pretty soft
                        and bend easily or is it hard to bend?
