Home Forum Ask A Member TUBE BENDING
Viewing 9 posts - 21 through 29 (of 29 total)
  • #69034
    bob-d
      Tubs,I would say it was pretty soft, equal to copper.
      Bob D
      #69063
        Back in the late 70’s we started using this
        for fuel line. This may be the same as what
        you have bought. It was so much easier to
        use than the steel line but in the beginning
        we questioned whether it would hold up as
        it seems to be even a little softer than copper.
        Going on to forty years an there was never
        a failure that we know of. You can polish
        it which would simulate the nickel plating.
        Cant find it in 5/16" though.
        Here’s some eBay links.
        https://www.ebay.com/itm/Speedway-Motor … 1438.l2649
        https://www.ebay.com/itm/Challenger-Alu … 1438.l2649
        It list for less on the Speedway sight but don’t know what shipping will do to the total.
        #69073
        amuller
          Wall thickness not given…..
          #69091
          William Jatzek
            quote outbdnut2:
            Copper is soft….up to a point – you bend or otherwise stress it too far, it work-hardens and gets brittle.
            Copper will work harden when being bent or hammered on. To soften it again heat it up kinda red and quench in water just the opposite of steel. I had to do some tricky bending on copper water pipe ( packed with sand ) where I had to soften it several times. When I was done forming, the pipe was dead soft from heating and quenching to harden it back I just wiggled it back and forth and you could feel it harden back up. Bill,
            #69093
            William Jatzek
              If you want to bend small copper tubing tight radius 1/4” to 3/8” I would just fill it with melted lead or cheap solder just heat the copper and solder and fill it as a liquid then find something round of the approximate radius and bend the tubing around it then take a propane torch and melt the solder or lead out. I have several tubing benders and small V belt type pulleys I have accumulated over the years to aid in bending. If possible I will try doing it cold but sometimes the fitting is to close to bend and then you have to use your imagination. Bill,
              #69111
              bob-d
                Tubs, good links. I will use them in the future. Much cheaper than what I bought which was sold individually by the foot.
                Bob D
                #69125
                  I’ve tried filling the tubing with sand (no heat) Didn’t help.
                  I believe filling the tubing with solder should work but
                  while the majority will run out not all of it will. Trying
                  to blow it out may work if you reheat the tube several
                  times. My thinking is if you whip the hot tube most of
                  the solder should come out. To much trouble for me.
                  I was thinking of trying to melt some trimmer line to
                  fill a straight piece of tubing maybe 6" long. Then if
                  I could get it out I would spray it with some kind of
                  lubricant, sticking in some tubing, make the bend, and
                  see if I could pull it out. The biggest problem with this
                  is melting the trimmer line. Thinking is probably as far
                  as I’ll go here.
                  This is new to me.
                  quote Billy J:
                  I will definitely be giving this a try to see if I can get the same result.
                  #69127
                    how about fill with sand then add solder after the sand both ends just put enough in for a little more than the bend
                    #69137
                      Bet it stunk…plastic melted = toxic fumes. I’ll buy a 90 & correct,
