Home Forum Ask A Member Vintage Mercury Racer ID Help Needed
  • #178506
    outboard315
      I would like to point out it’s not a Quincy dump exhaust, it’s a homemade to look like a Quincy dump exhaust.
      The power head is a KH7 or wizard equivalent. There is no fuel pump or vacuum pump boss so it was a gravity feed carb motor. Once the pump was put on another carb was put on at the same time.
      I know the early 60s merc 200 power heads fit (white motors) and some of the phantom black motors fit but there is a relief at the front that needs to be filled with a plate or RTV.
      #178507
        If you use a 200 PH it will not have much spline engagement. maybe 3/8in.
        #178539
        bayham3261
          I pulled off the prop and noticed some prop shaft side-to-side play. Seems like the bearing behind the prop maybe shot. Is this common? How do these gearcases come apart so i can check out what the condition of the internals?
          A little information is a dangerous thing!
