Home › Forum › Ask A Member › water in RD-19 manifold
- This topic has 5 replies, 4 voices, and was last updated 6 years ago by
RICK EICHRODT.
February 26, 2020 at 11:18 am #195901
I failed to plug two holes, the hose nipples near the carburetor, before giving an RD-19 a quick pressure wash. Should I worry about the little water that got sprayed in? Some did fo sho ’cause I turned the crank and a little dribbled out of the lower one.
Thanks,
GJMGP
February 26, 2020 at 11:25 am #195902Well, I am assuming you can’t start it to expel the water, correct? You sure don’t want that water to settle into any of the bearings…It might be easiest to pull off the intake manifold and fill the crankcases with light weight oil….Then turn it over to make sure the oil gets into the bearings….
February 26, 2020 at 11:33 am #195905Correct. I can’t start it. It’s taken all apart. I did reinstall the flywheel and pulled it over with rope though. That’s when the water sputtered out of the nipple. Should I have done that with sprk plugs installed? They were out. I had taken them out to get a little more speed on the rope pull. But now I’m thinking I need that extra pressure.
GJMGP
February 26, 2020 at 11:39 am #195906I would pull the intake manifold off and see how much water got in there. If it’s just a little bit of water you can spray a bit of WD-40 and clean it up. I wouldn’t want to rope the motor over and pull a big slug of water into the crankcase. If there is water already in the case, then as Fleetwin noted, you should spray some fogging oil into the case and rope the motor over to get that oil into the crank bearings.
"Every time you remove a broken or seized bolt an angel gets his wings."February 26, 2020 at 11:44 am #195907Dang! Was hoping I wouldn’t have to ‘cuase I always mess up the paint on those screws. But ‘ll do it. Thank you.
GJMGP
February 26, 2020 at 3:01 pm #195917You might not have to take it apart. Get some kerosene and fill the inside of the block both through the spark plug holes and the carb intake. Let it soak…then drain. Fill with clean oil…..drain that. That should remove any traces of water.
