Home Forum Ask A Member water leak in engine
  • #245154
    Carlasdaddy
      I have acquired a 1956 Evinrude 7.5hp power head attached to a 1958 lower unit. I removed the power head to dis-connect shift rod and replaced the impeller in lower unit. I re-attached the power head with a new gasket and torqued attaching screws to specs. When I started it up in a barrel of water, water started coming out between the power head and lower unit. Any ideas what is wrong? Should I have used a gasket sealant on the new gasket?
      • This topic was modified 4 years, 7 months ago by Carlasdaddy.
      #245161
        did you use the proper gasket…. they have different designs based on year I do not think sealant is needed to mate the 2 surfaces
        you need 18-3001C gasket on a 1956 to 1958
        https://www.vintageoutboard.com/collections/johnson-evinrude-water-pumps-impellers-lower-units
        check the design pattern on the new… lower unit
        #245162
          This same question keeps popping up. So, have you checked the core plug in the bottom of the head or not?
          #245163
          Carlasdaddy
            Yes, I used the proper gasket.
            #245164
            Carlasdaddy
              Do you have a picture or diagram of where the plug is located?
              #245169
                There’s two of them in the head. Top and bottom.
                Johnson-AD-Cylinder-Head-1
                #245178
                  Mumbles, aren’t there three of them? Two shown in your pix plus one on the bottom, straight down from the top one?
                  #245179
                    Item #47. Sez 3
                    6.-Powerhead
                    6.5-Powerhead-Parts-List
                    • This reply was modified 4 years, 7 months ago by frankr.
                    #245201
                    Carlasdaddy
                      You found the problem for me. I removed the power head and found that the welch plug facing straight down was missing. Now the problem is where can I get one. Not available on eBay and Marineengine.com only carries parts back to 1957. Do you know where I can buy it?
                      #245206
                        Yup but my ’56 diagram only showed the two. I should know better than that.
