Home Forum Ask A Member Water pump on a 1963 Mercury 9.8
  • #238214
    paulied
      I’m about to change a water pump on a 1963 9.8 Mercury Are there any surprises i will encounter ? never done one before
      #238216
        just unbolt the LU slide the pump housng up the drive shaft …..replace impeller (use a bit of liquid soap) install the spline O ring if it has one grease the splines….. not the top end line up shaft and water tube close it up 🙂
        • This reply was modified 4 years, 10 months ago by JACQUES.
        #238225
        Fred Hickman
          WTB – 12′ Whirlwind to run my 57′ Fastwin on.
          #238226
            ….? nothing to do with Merc water pump…. try classifieds…
