Home Forum Ask A Member Wear/looseness in mag plate bearing
  • #172622
    olcah
      Every OMC mag plate I have worked on has looseness in the bearing if you lift the edge of the plate up and down. Lift up/push down definitely changes the points gap. Wear would increase this play. I expect that to cause the points gap to change when the motor is running. Usually I just time with a ring at throttle midpoint and ignition works fine. But how much play is too much? Short of replacing the plate with NOS is there a fix? Wondering what others think about this?
      • This topic was modified 7 years ago by olcah.
      #172640
      olcah
        I broke down and bought a NOS mag plate as the best plate I have seems extra loose. Still interested in anyone’s thoughts on this problem as looseness of the mag plate bearing seems very common.
        #172662
          There are kits to update some models to better mounting system if you have a motor that you really care about. Sorry, I’m off camping and don’t have the part numbers with me.
          #172670
          lloyd
            You can make a bushing out of thin brass sheet (shim stock) and mount it inside the mag plate hole. I have done it before and it worked for me.
            #172671
              I have had electrical grounding issues with loose mag plates too. Be sure to run a bonding wire from the plate to the cylinder block, it helps!!
              #172672
              chinewalker
                I’ve tightened up a few by dimpling the bearing surface on the powerhead with a punch. Two dimples, vertically, at all four points of the compass, eight dimples in all.
                #172689
                  For anyone interested, the update kit is part #580871.. It is specified for 28-33-40hp motors but will fit a bunch of others by maybe drilling/tapping a missing hole or two.
                  #172691
                    You can get the kit Frank mentions, or simply dimple the brass bearing surface. I do a LIGHT tap with a punch every 90 degrees, 4 total. Just light, it really tightens it up!
                    #172719
                    JOSEPH BRINCAT
                      Frank, what does the ” the update kit is part #580871.” consist of? a whole new mag plate? or just the brass insert ? Is any machining work needed for truing a worn boss on the crank case?
                      #172725
                      seakaye12
                        Here’s a Picture of the “dimpling process”. It’s a picture that has been floating around the internet for years. I’d love to give credit to the author but I don’t know who it is.
                        Adjust_Mag_Plate_Support
