Home Forum Ask A Member what is it 4hp lightwin 2001 510 82
  • #229820
    HARRY D. NICHOLSON
      Canadian (serial numbers) are normally unrelated to USA (serial numbers). (corrected.)
      #229896
      need2fish
        Further to Harry’s comment….
        I believe he is correct, and the pop rivets are from excess inventory at the end of one year having their ID tags removed and replaced with the new year’s model #.
        #229897
          so my 4hp became a 25 hp at year end ??
          #229901
            Perfect motor…. 1 bad coil and 2 bad condensers tested on W.Mohat test box 🙂 Compression to be tested….but I am not worried
            #229906
              Since when? I’ve never seen that but the serial numbering can be different.
              #229962
              HARRY D. NICHOLSON
                Mumbles is correct, the serial numbers are way different than usa and the years made are usually later than you would think.
                Check the numbers on the welch plug on the powerhead. They should match the data plate.
